simple question
i have a 91 LX 5.0, i got a stock gears in the back, and i put in a 140 cluster, and the speedo is way off and i think the speedo gear worked with an 85 mph would gear would i put back in there or wat should i do?
NO NO NO u have to change the speed o gear ont he speed sensor or the tail shaft of the trans. if you go to any ford dealership hey will get u the right gear for the speed o.
Also i am shure that if you go to a aftermarket gear site they will have the gear for the speed o avalible.
Good luck hope everything works out
BigMG
BigMG
yea Im def sure that in 89 they changed....plus the 87-88 85 MPH cluster is slightly different because it has a dummy light panel on the bottom right....and you have to mod the newer 140's to fit in the 87-88's I believe....so in dont really know why his had the 85?
