EGR question
Old Jan 12, 2006 | 08:36 PM
Tims 88GT's Avatar
Tims 88GT
Default EGR question
Hello everyone, as most of you know i have been having a problem with my car missing, today i unpluged the egr and my problem went away, my question is what is the egr for exactly and what does it do, it stands for exhaust gas recirculation right?
Old Jan 12, 2006 | 09:24 PM
cammedlx's Avatar
cammedlx
Default RE: EGR question
Its manily just a smog related sensor...but with it still bolted on and pluged up if the egr is stuck open it will cause somthing similar to a vacum leak and will cause the car to run poorly,i have deleted the whole egr with a self made block off plate and my car runs great without it..i looked at the egr sensor simulator and the only thing they do is keep the check engine light off...
Old Jan 12, 2006 | 10:48 PM
86HOGT's Avatar
86HOGT
I made my own EGR simulator. The position sensor off the valve!
If you unplugged it and the problem went away then that tells me that vacuum was getting to the valve and keeping it open. Now, the only thing stopping it from getting vacuum and recieving vacuum is the EVR solenoid located on the pass. side strut tower.
Old Jan 12, 2006 | 10:53 PM
Joel5.0's Avatar
Joel5.0
ORIGINAL: 86HOGT
Ditto.....or having the wrong vacuum line connected to the EGR valve. It Happens! My 2¢.
Old Jan 13, 2006 | 12:02 AM
stanglx2002's Avatar
stanglx2002
did you unplug the sensor on the passenger strut tower brace like i said before
Old Jan 13, 2006 | 12:19 AM
90Mustangfan's Avatar
90Mustangfan
I ♥ Acer
I had similar problem that solonoid it would just keep bleeding off the vaccum causing a vaccum leak, it wouldnt let the egr valve open, I went to a local junkyard picked up 1 of them, problem fixed with that EGR vaccum solonoid, thats what its called anyway, the junkyard gave it to me for free, it was small item, probally the value of the part is like a buck and it cost more than that to get in, so they gave it to me for free.
Old Jan 13, 2006 | 01:11 AM
Tims 88GT's Avatar
Tims 88GT
no i only unpluged the egr, i have a few of the solonoids around so im going to put another one on it and see what happens. i think that is all it is, i think it is getting vaccum the whole time, which is keeping it open. thanks for the help
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
