Quick Flywheel Question
Old Jan 15, 2006 | 11:35 PM
fastfox86's Avatar
fastfox86
Default Quick Flywheel Question
Hey all, I finally have 20 side projects done that I started while doing my T-5 swap and now it's time to get down to the install. My question is this, I did not mark where the weight was on the AOD flexplate for the imbalance and I was wondering if I need to install the the flywheel at a certain point or positiong for it to work properly. As far as I can tell there's no counterweight on the flywheel or anything and I want to know if I can just bolt it up and go. Any help would be appreciated.
Old Jan 16, 2006 | 12:15 AM
nitrous_bob's Avatar
nitrous_bob
Default RE: Quick Flywheel Question
i never marked it on my old car when i did the clutch, and it was fine.
i did however mark it when i did the clutch on my current car 2 weeks ago.
Old Jan 16, 2006 | 12:21 AM
fastfox86's Avatar
fastfox86
Thanks that's good to know.
Old Jan 16, 2006 | 12:26 AM
angcobra's Avatar
angcobra
It only goes on 1 way on the 5.0, the question is did you use the same size counter weight (it is built into the flywheel not just welded on like flex plate)? There are 3 out there for 5.0 28 oz, 50 oz, and neutral. You just have to make sure you traded to the same or the engine will be out of balance.
Old Jan 16, 2006 | 01:42 AM
fastfox86's Avatar
fastfox86
It's a 50 oz. and I'm pretty sure the flywheel is 50 as well. Which ones came with 28 oz flywheels?
Old Jan 16, 2006 | 03:19 AM
Tims 88GT's Avatar
Tims 88GT
you need bolts for a flywheel to not a flexplate, the flexplate bolts are to short and yea you get the picture pop the clutch a few time and wops there goes the flywheel.
Old Jan 16, 2006 | 03:41 AM
fastfox86's Avatar
fastfox86
I got the flywheel bolts when I bought the flywheel. They are the longer ones.
Old Jan 16, 2006 | 03:53 AM
Tims 88GT's Avatar
Tims 88GT
good
Old Jan 16, 2006 | 06:34 AM
Magiarn71's Avatar
Magiarn71
ORIGINAL: fastfox86
Non HO 5.0 302's had the 28 oz. (Like in the early mustangs and later t-bird) I think you would use a 28 for a 347 stroker also.
Old Jan 16, 2006 | 10:32 AM
86HOGT's Avatar
86HOGT
It can only go on one way...
