JUST CURIOUS,BUT WHERE DO MOST BLOCKS CRACK OR BREAK AT?
Old Jan 20, 2006 | 11:37 PM
grabbem88's Avatar
grabbem88
Default JUST CURIOUS,BUT WHERE DO MOST BLOCKS CRACK OR BREAK AT?
i have always seen them break/crack at the webbing or crank cradle..
just trying to get an insight on this.
Old Jan 20, 2006 | 11:41 PM
Tims 88GT's Avatar
Tims 88GT
Default RE: JUST CURIOUS,BUT WHERE DO MOST BLOCKS CRACK OR BREAK AT?
why do you think that is your problem? most of the time it will crack the webbing, or completley take the bottom end out, and sometime they split down the center.
Old Jan 20, 2006 | 11:42 PM
Obsol3te's Avatar
Obsol3te
If you're running a main cap girdle, I hear the place to be is right down the lifter valley.
Didn't want to wait and find out though, so I upgraded.
If you're considring getting a stronger block, go for it
Old Jan 20, 2006 | 11:46 PM
grabbem88's Avatar
grabbem88
don't think so,getting leary,and don't have the big$$$for another.
when i tore down the top end i did find a few things.
intake gaskets were smashed/melted
exhaust side on one of the heads was nice and shiny(no carbon)
same head,and port side.i found some hot spots/or pitting found it with a magnafying glass though.
and head gasket on that same side just fell off.
other side the gasket stayed on the head when pulled off.
Old Jan 20, 2006 | 11:48 PM
grabbem88's Avatar
grabbem88
howmuch for a bare block? i'm sure the internals are good they are all forged is i thought was a waste on a basically factory block.
ORIGINAL: Obsol3te
Old Jan 21, 2006 | 12:03 AM
FullAuto's Avatar
FullAuto
Right down the lifter valley.
Old Jan 21, 2006 | 12:55 AM
uedlose's Avatar
uedlose
They crack form the crank up all the way to the lifter bore back to front or front to back and the main girdle well it didnt help ours.then the crank twist and flexs due to the wide clearances and lack of support then it cracks and brakes.and well by this time it is spewing fluid out all over the track/street and it is getting under the rear tires ET streets no tread and the rear starts to slide and sway the the OH-**** meter is rising well you get it.all while you are moving at 115+ [IMG]local://upfiles/7534/1D12429346204DCBB03966DF50FD9179.jpg[/IMG]
[IMG]local://upfiles/7534/627AE6D34F9A418498FC835605675ED6.jpg[/IMG]
[IMG]local://upfiles/7534/00A049C0F7D8488FA63123E0623F8767.jpg[/IMG]
Old Jan 21, 2006 | 01:03 AM
grabbem88's Avatar
grabbem88
well i found out my afr's were/are twisted so my block is ok..
Old Jan 21, 2006 | 01:19 AM
Tims 88GT's Avatar
Tims 88GT
get a r302 i think you can get them for 1300 or so ask OB i think that is what he has
Old Jan 21, 2006 | 01:20 AM
Obsol3te's Avatar
Obsol3te
ORIGINAL: grabbem88
ORIGINAL: Obsol3te
A bare block, well arnt you building a 351?
I paid around 1700 for my bare R302
But I don't have to worry about it splitting, ever...
