1970 rearend
Old Jan 23, 2006 | 02:32 AM
posnick's Avatar
posnick
Default 1970 rearend
will a 8.8 rear from a 1970 mustang be a direct bolt in on a 83 mustang? also how can you tell if it is posi or not
Old Jan 23, 2006 | 02:33 AM
primetime5.0's Avatar
primetime5.0
Default RE: 1970 rearend
correct me if im wrong but dont those rears use a leaf spring setup?
Old Jan 23, 2006 | 02:36 AM
posnick's Avatar
posnick
they do that is one of the reasons i was wondering. i have a welder so i could weld on new hardware
Old Jan 23, 2006 | 02:37 AM
primetime5.0
im sure you could modify it to work, but i think the widths are different too
Old Jan 23, 2006 | 03:41 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
they use either an 8inch or nine inch setup for v8s not an 8.8!
Old Jan 23, 2006 | 03:52 AM
primetime5.0
uhh whats wrong with an 8.8?
Old Jan 24, 2006 | 03:42 AM
posnick's Avatar
posnick
i didnt think ford had a 8". 7.5 ", 8.8" or 9" 86 and newer v8 has 8.8
Old Jan 24, 2006 | 04:45 PM
waxyourboard's Avatar
waxyourboard
Ford made a 7.25" , 7.5" , 8" , 8.8" , and 9" rearends
The 7.25's were in 60's six cylinder cars, and man were they bullet proof... they could withstand up to almost 100 horsepower.
The 8's were used in the mild v-8's of that era, and the 9's basically an option or used on the high performance v8's and bigger cars
7.5's are used on the newer six our four cylinder cars i think? and the 8.8's on newer v8's
Edit: the '70 mustang rear end (9' probably) most likely won't fit your car... what you need to check is the width of the axle. If that's within about an inch, you can always just take it to a welder to have newer shock/spring mounts welded on
Old Jan 24, 2006 | 05:00 PM
4eyedfreak's Avatar
4eyedfreak
I dont know if this helps any but i know that my 83 came with a stock 7.5 and i used a 8.8 from an 88 gt and completely redid evrerything. I am almost positive that the 79-85 all had 7.5 inch rear ends. I personally would not get a rear end from a prefox body car for my fox body.
I think that the rear end from solid framed mustangs are wider in diameter (pumpkin) or deeper i am not sure. But you could have drive shaft problems then.
I could very well be wrong
Old Jan 24, 2006 | 10:46 PM
posnick's Avatar
posnick
you are right. i went and had a look today and its totally different. the problem i have is every 8.8 i find is $350 and up, this was only $100. guess i'll keep looking
