351W block
Old Jan 24, 2006 | 04:04 AM
nick366's Avatar
nick366
Default 351W block
I know this topic has been on here a few times but i tried to search and could not find my answer. Im just wondering what make and year fords came with 351w that would be used for a swap into a fox. thanks for the help.
Old Jan 24, 2006 | 09:54 AM
93Mustang5.0's Avatar
93Mustang5.0
Default RE: 351W block
I could be very wrong but to my knowledge I believe the 73 mustang mach 1 had a 351W in it. Like I said I probably am wrong though lol
Old Jan 24, 2006 | 10:22 AM
95StangCobra's Avatar
95StangCobra
The 95 saleen 351 had a 351w, but good luck finding one
Old Jan 24, 2006 | 12:35 PM
mkspeed26's Avatar
mkspeed26
well, are you looking for a roller block or a non-rolloer block? 351Ws came in nearly every big vehicle Ford and Lincoln made during the 70's. They were in truck for a very long time; up through the 80s. I got mine out of a '78 tbird.
Old Jan 24, 2006 | 01:25 PM
transam396's Avatar
transam396
believe it or not there is a 351 powered saleen mustang on autotrader right now they only want 50k for it,
the same place also has a 95 mustang r that is supposed to have jut 190 miles they only want 36k for it
Old Jan 24, 2006 | 02:03 PM
nick366's Avatar
nick366
which cars or trucks came with the roller blocks?
Old Jan 24, 2006 | 03:12 PM
primetime5.0's Avatar
primetime5.0
get one that is a solid block then convert it to a roller
Old Jan 24, 2006 | 03:15 PM
88BlueGT's Avatar
88BlueGT
You could do that OR you can just find a roller. You can also get them out of Bronco's. I was going to get out out of a Bronco for $300 bucks and it was already pulled. I would just start calling up the junkyards and asking.
Old Jan 24, 2006 | 04:51 PM
wildcobrar's Avatar
wildcobrar
You can use a older 351W block to go rooler though it is expensive to do so. The cam base circle is different and you need to buy the linked lifters or the retro kit. 351 Windsors were made from 69 to at leats 96. I snagged one from a 94 F150 4X4 and it is a roller block with all the hardware you need for a great performance build. I believe they came in Full size Broncos and the F150 from 92/93 till 96. That would be your cheapest build though you can retro an older block there are more thinds you need to deal with or you will have oiling issues at the lifters. Hope this helps.
Old Jan 24, 2006 | 05:30 PM
nick366's Avatar
nick366
thanks for all the help guys.
