Battery
Old Jan 29, 2004 | 10:11 PM
Ormist's Avatar
Ormist
Default Battery
Hey, well my battery is dead what battery should I replace it with? I mean do the different battery brands make much of a difference, also I had a 580 (amps?) but Advanced Auto Parts said that the standard for my car is 550 BUT Auto Zone said the standard for my car is 580. So what should I go with??? Also I was planing to change my battery wire to a 4 gauge, I just figure bigger is better.. is there any reason why I shouldnt???
Old Jan 29, 2004 | 10:54 PM
makarovboy's Avatar
makarovboy
Default Battery
By all means, replace the cables to larger gauge. Less heat, more amp draw. When I replace my battery I'm going to the small Optima red top. $129 at summit, totally maintenance free and 800 cold cranking amps, fully sealed and can be mounted in any position.
Old Jan 29, 2004 | 11:01 PM
Ormist's Avatar
Ormist
Default Battery
More amps means....
Old Jan 29, 2004 | 11:15 PM
makarovboy's Avatar
makarovboy
Default Battery
More cranking power on cold starts, the battery stays charged when sitting for long periods. Just do one thing regardless of which battery you buy. Don't put it in when partially charged. Make sure it has a full charge, because alternators aren't designed to charge a depleted battery, it blows the diodes.
Old Jan 29, 2004 | 11:19 PM
n2o44's Avatar
n2o44
Default Battery
CHECK FOR SOME DRAIN ALSO , CALLED PARASITIC DRAIN TEST , AND A PARTIAL BAD ALT , OR A PROB IN THE STARTER CRK FOR HIGH RESISTANCE TO SEE IF ANY OF THOSES ARE A PROB, CUZ I SUCKS TO PUT A BATT IN AND STRESS IT SO IT DIES SOON AGAIN
Old Jan 29, 2004 | 11:35 PM
Ormist's Avatar
Ormist
Default Battery
How would I go about checking those, would I have to take it to a shop or could I do it on my own? If I can do it on my own, details if you can...
Old Jan 30, 2004 | 12:04 AM
n2o44's Avatar
n2o44
Default Battery
if you have a digital volt meter at best i can show you how to get some pretty good answers.
Old Jan 30, 2004 | 05:14 PM
mkspeed26's Avatar
mkspeed26
Default Battery
Originally Posted by Ormist
More amps means....
</P>
amperage is the amount of flow, while voltage is the power of the current.</P>
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
logan409
Sep 26, 2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
Art161
Sep 9, 2015 10:33 AM
