squeaky
ever since i put my bbk UDP on.....when my car idles it squeaks....not constant.....sounds exactly like crickets do on a summer night....almost identical.....what could be the cause??
Its possible. Throw some WD-40 in the pulleys and see what it does.
I would try a new belt, it may say it takes a stock belt size but as a belt heats up it stretches and by putting smaller pulleys on may cause it to slip.
Watch your battery voltage closely and make sure you alt. isn't doing the squeaking.
Those can get pretty loud when the bushing start to go.
If it is the belt, you can also try using some belt dressing and see if that works.
