Injector size?
Old Feb 3, 2006 | 04:57 PM
ReVz's Avatar
ReVz
Default Injector size?
whats the stock injector size on a 94 GT? and if I was to upgrade them what size should I go with?
Old Feb 3, 2006 | 04:59 PM
88BlueGT's Avatar
88BlueGT
Default RE: Injector size?
The stock injector size is 19lb. You shouldnt need to upgrade them unless you exceed their power limit which it right around 300hp; give or take a few. And if you were to upgrade 24lb injectors is the next step up.
Old Feb 3, 2006 | 05:06 PM
ReVz's Avatar
ReVz
hmm alright... I think next up for this is car is 3.73 Gears. Now to start saving.. thats going to be the fun part
Old Feb 3, 2006 | 05:31 PM
88BlueGT's Avatar
88BlueGT
LoL thats always the fun part. Also, is it an auto or manual? If its an auto I would def go with the 4.10's
Old Feb 6, 2006 | 03:55 AM
Beegle8950's Avatar
Beegle8950
If you adjust your fuel pressure form 39 psi (stock) to 60 psi, then the 19 lb injectors are good to around 330 hp. 24 lb injectors can feed a 400 hp engine at 39 psi, so this would be plenty.
mltdwn12
Sep 23, 2015 08:54 AM
Demodulates
Sep 18, 2015 11:14 AM
pimp2303
Sep 17, 2015 08:45 PM
uedlose
Sep 10, 2015 01:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
