Crank Pulley help...
Old Feb 12, 2006 | 01:14 AM
Black Snake's Avatar
Black Snake
Default Crank Pulley help...
As you all know I ordered my SC-Trim Supercharger. And I have a feeling that 6PSI isnt going to be enough to satisfy my needs.
So my question is this, I heard somewhere, where I can up the boost by changing the Crank pulley and not void the waranty on the Charger.
Ive been searching for the past hour for a 6 rib crank pulley to do this but I cant find it anywhere.
Can someone help me find it? Or have a part number?
Old Feb 12, 2006 | 01:19 AM
grabbem88's Avatar
grabbem88
Default RE: Crank Pulley help...
have you checked EBAY?...iv'e seen a crap load when i was looking...before my heads took a crap on me.
Old Feb 12, 2006 | 01:34 AM
Black Snake
Not yet im kinda nervous to check ebay
Old Feb 12, 2006 | 01:35 AM
grabbem88's Avatar
grabbem88
why they were all brand new from known companies
Old Feb 12, 2006 | 01:48 AM
Black Snake
Ok got done checking ebay I found two of em.
Will these work
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
And
If I can get it for that price ima buy it.
Old Feb 12, 2006 | 02:00 AM
grabbem88's Avatar
grabbem88
i like the second one
Old Feb 12, 2006 | 02:03 AM
Black Snake
K Ill see which one sell for cheaper
Old Feb 12, 2006 | 02:04 AM
FullAuto's Avatar
FullAuto
First link is to for a 8 rib blower pulley and 6 rib accessory drive. Is your blower 6 or 8 rib?
Second link lists it will make 12psi with a 2.87" blower pulley. What size is the stock blower pulley? I thought your kit had a stock 6.87" crank pulley. If that's the case, you'll only gain maybe 1psi.
Old Feb 12, 2006 | 02:08 AM
Black Snake
Doesnt 1 psi make an extra 17 hp?
Old Feb 12, 2006 | 02:13 AM
Black Snake
Found the specs on the SC-Trim
Compressor matched, computer aided designed and machined Vortech Centrifugal Supercharger Head Unit
6-Rib Supercharger Drive Pulley 3.33"
6-Rib Crank Pulley 6.00"
OEM style single cast 356 Aluminum Mounting Brackets heat treated to T-6 specifications for strength
Premium Drive Belts
Heavy-duty Mounting Hardware
Heat resistant Silicone Hose Couplings
Premium grade Flex Hoses
Stainless Steel Clamps
Integrated Belt Tensioner
Tie Wraps
FMU with fuel line Assembly
Oil Feed and Oil Drain Assembly
Discharge Assembly
Air Intake Assembly with K&N Air Filter
Step-by-Step, fully Illustrated Installation Manual
3-Year Warranty on most systems
Boost Upgrade Kit Available, sold separately (part number: V8C101-001)
