SUGGESTIONS???????
SUGGESTIONS???????
I have a 92' notchback. The exhaust and transmission have been changed to 3 chamber flowmasters, bbk headers, and off road h pipe and a c4 w/ 3500 stall..... as well as some 3.73 gears. I am about to start on the engine. I am looking to buy some Ford Racing heads (the twisted ones) and a cobra intake manifol w/ a 1" spacer. I am also going to replace my springs and get a custom cam put in. Does this sound like a good set up any suggestions comments. Please!
SUGGESTIONS???????
Originally Posted by Milky
I had the cobra intake and replaced it with TFS Track Heat. I liked the cobra a lot butt the trick flow was better... look into tfs
trick flow = <IMG src=smileys/smiley16.gif border="0"></P>
SUGGESTIONS???????
Trick Flow Twisted Wedge heads and Track heat will blow your mind. The custom grind is cool, but check out TFS' cams. Again, they're made to go with other TFS parts so it might work out better than the custom grind. Either way you'll be really happy<IMG src=smileys/smiley2.gif border="0">
SUGGESTIONS???????
I am about to order a set up from mustangwarehouse.com. TFS track heat intake w/ twisted wedge heads and a TFS stage 2 cam. C&L 73 mass air meter and an Accufab 75mm Throtle body. Does this sound good to you guys...Has anyone heard anything about mustangwarehouse.com...they are giving me a great deal...around 1600 for all of the above...
