sticking RPMs
when i give the car a bit of gas, it revs up and sticks at that rpm for about a second, then drops back down. it gets really annoying in between shifts. could this be a leaky injector or maybe a dirty sensor?
RE: sticking RPMs
it's your vss reading your rpm's to your actual speed.
RE: sticking RPMs
vss.....? and how do i fix this?
RE: sticking RPMs
vehical speed sensor...unplug it if you want,but you might run into problems....car might die more?
RE: sticking RPMs
is there a way i can just take it apart and clean it?
RE: sticking RPMs
no it's a plug that goes into your speedo gear in the trainy.....now if you don't have it then there is something else going..maybe??? orange,and green wires...
