Tuning for 331
Old Feb 24, 2006 | 11:23 AM
88Stang331's Avatar
88Stang331
Default Tuning for 331
Current plans are:
331 Stroker
Trick Flow track heat 185 CNC ported heads
Anderson ford motorsports b-41 blower cam
Pro-X max quench pistons -13cc
Edelbrock Performer RPM II upper/lower
Mass Air
Aluminum Drive shaft
3.73 Gears
Eibach Springs
My question is how big of injectors/TB i need to go with.
Old Feb 24, 2006 | 11:44 AM
angcobra's Avatar
angcobra
Default RE: Tuning for 331
the build looks like it is headed towards forced induction, is that the plan? If so, you might want to size based on that. With 10 to 12# of boost I would guess 75 MM and 42# injectors.
Old Feb 24, 2006 | 11:50 AM
88Stang331's Avatar
88Stang331
Yes i am going to end up using Forced induction in the form of a turbo probably. Haven't decided for sure yet. What brand injectors would you suggest?
Also how much power do you think that would be putting to the ground with 12* of boost?
Old Feb 24, 2006 | 12:01 PM
angcobra's Avatar
angcobra
I would be hoping for mid 400s RWHP
Old Feb 24, 2006 | 12:06 PM
88Stang331's Avatar
88Stang331
how much before the power adder?
Old Feb 24, 2006 | 12:46 PM
FoxRod's Avatar
FoxRod
ORIGINAL: angcobra
No way. Expect a lot more than that. I have a turbo on a completely stock motor. No heads, cam, or intake and I have 372 rwhp with only 6 to 8 psi. With 12 psi and the mods you have plus the throttle body expect 500+ on a turbo. A S/C may be a different story though. I hope your not running a stock block when you put the turbo or SC on. You'll probably crack it in half with that much power.
Old Feb 24, 2006 | 01:19 PM
88Stang331's Avatar
88Stang331
I will most deffinately not be using a stock block, i will be using the DSS Pro Bullet 331 Short block, either that or with a Dart Block haven't decided yet.
Old Feb 24, 2006 | 01:32 PM
stanglx2002's Avatar
stanglx2002
i would go with a dart or a R302
Old Feb 24, 2006 | 01:35 PM
88Stang331's Avatar
88Stang331
And i would love to do that, seeing as it has a 4 bolt main, however it costs a bit more.
Old Feb 24, 2006 | 01:43 PM
FoxRod's Avatar
FoxRod
Yeah I'm in the process of buying the Dart block with a 331 setup in it. That sh*t is gonna be sweet when I get it and put it in. Then I'm gonna up the boost and try my best to hit over 600 rwhp. The short block that I wanna buy is rated up to 1500 so I'll just boost the f*ck outta it. ha ha ha. Yeah for me.
