Any Clutch Suggestions?
my clutch is on the way out and i am looking at aftermarket clutches to put in. i would like a clutch with great grabbing powerbut still not be a bear to push to the floor.i have just started a new job with more money so i plan on modding the engine and drivetrain soon but the clutch isfirst on the list.i am looking at the king cobra clutch from ford motorsports.does this onewear well? any suggestion would be appreciated.</P>
i used a king cobra clutch and tought it was trash, look into a centerforce, for example my used centerforce worked better than the new king cobra, so i put the centerforce back in, mineis the gold one triple friction or something. FMS paroducts are not as good as other after market parts and are the same price or more shop around.
your centerforce was probably a dual friction, there are also the centerforce I (30% greater than stock) andcenterforce II (60% gts). The dual friction has 90% better grip than the stock one. you can get them through jegs and they cost about as much as a king cobra clutch.
whoa now. where did you find centerforce clutches for as much as the king cobra?!?! my king cobra cost 200. centerforce is around 300-350 last time i checked...maybe i'm wrong? either way, i love my king cobra clutch. smooth, no chatter, and strong as hell. EDIT-get a new flywheel? i wouldn't do that. it makes the ride too rough. and you guys are saying that like it's cheap. flywheels cost about the same as a clutch, if not more...i wouldn't do it even if i had the cash. <edited><editID>FiveOhNo</editID><editDate>38032.0399189815</editDate></edited>
Sure, get a new flywheel, I am going to get one when I get a new clutch, in about a year. Every poung that the engine doesn't have to crank is more power to the tires. If nothing else, it will make you revs in neutral sound better because the throttle will be more responsive.
