How much Hp?.
I was curious to what kind of hp you all thought i would get out of my setup. I have a 86 gt with 306. It has stock rods on probe dome pistons. around 11 to 1 compression ration. the motor has been balanced and blueprinted. I have windage try and all arp bolts. It has afr 165cc heads with 1.6 roller rockers. trick flow stage 2 cam and edlebrock performer intake. I think it has 24lb injectors and mass air meter. Cant remember what exact number injectors are. one step up from stock i know. 190 fuel pump. a/c eliminator, smog pump eliminator. cold air intake and bbk headers to off road h-pipe with flow master exhaust. I may be forgetting some things, but pretty much every bolt on you can get on it.
only 300hp. is that at the wheels. i was thinking close to 400 at flywheel being on afr's website that is way they got on basicly my same setup other than carberated and 10 to 1 conpression. seems low to me.
