AOD or T5
I have a 1988 Mustang GT thats all stock except for some underdrive pulleys, headers, off-road h-pipe, flowmaster cat-back, and some 3.55 gears. Its an auto, and the best 1/4 ET I could get was a 14.73. The tranny has blown out overdrive so it needs to go. Im thinkin bout converting it to a 5 speed, but its so much more expensive to do that then rebuilding another aod. And ive seen some pretty wicked AOD fox-bodies. Im a lil tight for cash rite now, and unsure what i should do. what do you guys think?
-pick up an inexpensive aod
-Instal a Transgo HP shiftkit
-Instal a tranny oil cooler
-Instal a 3000-3500 rpm stall (torque) converter
-get a B&M hammer shifter
-Upgrade Cold Air Intake
-Upgrade Mass Air Sensor
-Upgrade Throttle body/egr spacer
ORIGINAL: Dave93VertGt
-rebuild it
-rebuild it
[quote]ORIGINAL: MustangMadness7
fixed. the car will be faster like this than with a manual, as well as more consistant. still, manuals are def more fun to drive.
+2
-rebuild it
-rebuild it
+2
i don't know the cost on auto parts but the manual stuff can be had for probably about
350-500 for a t5
100 for pedal assembly
200 for clutch
??? clutch cable
100 misc crap
looks to be under a thousand to me how much does all that auto stuff cost?
also what kind of et's is he looking at with the new auto tranny compared to the t5
350-500 for a t5
200 for clutch
??? clutch cable
100 misc crap
I'm looking to ease my way into the 13s without nitrous. And with a 3000 stall torque converter, do i still need stick with some 4.10s, which seems to be recommended with the AOD, or could I step down to a 3.73?
I SAY GET SOME 3.73 gears if its your only car!
here is a quote from Joe Munsch:
"My goal was to make my 15-sec. AOD coupe go 12s with as little expense as possible. I began by attacking the fundamentals.
Intake, throttle body, mass air meter, rear axle ratio and torque converter all had to go. I saved my Edlelbrock EFI intake, C&L 73mm MAF, BBK 70mm throttle body, 1-5/8" MAC shorty headers and 2-1/2" FlowMaster mufflers from my previous car. These parts had proven good so they immediately went on this car. The car wouldn't break the street tires loose at the track so I acquired a B&M Holeshot 3000 converter. Wow! What a difference that makes. Those changes got me to the 13s."
here's afew links on my favorites list that i use for notes on AOD stuff
http://fastblackaodcoupe.com/whats_new_1.html
http://www.alternativeauto.com/water...hives/aod.html
http://www.txchange.com/transgo.htm
