coilover question
Old Jun 24, 2007 | 01:57 PM
fordboyyfm's Avatar
fordboyyfm
Default coilover question
who here has installed coilovers on a foxbody. I couldnt get mine to go i right, it was like to bushings were too big. the top of the shock didnt come up nearly enought to get the nut on, i had to cut the bottome bushing in half to get it al to work, and if fits knd of loose, anyone else run into this.
Old Jun 24, 2007 | 04:42 PM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: coilover question
Yout have to cut the metal guide that goes through the bushing. I had to take about 3/4 of an inch off then they bolted down just fine. BTW I couldn't get my caster to come close to getting in spec when I aligned the car. I moved the k member and everything, it just wasnt' going to happen. Your going to need caster camber plate to get everything aligned. If you go as low in the front as I did your going to need a bumpsteer kit too, I have horrible bump steer.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
