My Headlights
hopefully my sig pic is big enough, if not, i'll post another, but my headlights are dim as f*ck...i was driving the car tonight, and could barely see 5 feet in front of me...is there adjusting that needs to be done? is it a fuse or something, or are the headlights just dim?
i can't keep driving like this....also, my dashboard light that lights up the speedmoter and tach is dim/out...is it worth it to crack in there and replace it?
i have after market headlights and they have this steel cup piece inside of it that the light goes into and then the light reflects back out of it but my bulb tip is dipped in a white color so i have like double the blocking i should have, so u need to get a bulb with nothing on the tip or some how get that peice out if u have that prob
ORIGINAL: Vader87
Replace the switch. I have the same problem with the headlights & I have brand new lights bulbs & housings.
ORIGINAL: Vader87
Just replying to your original question. Replace the interiordimmer switch if its not working right.
