How to increase ?
Old Jul 29, 2007 | 12:31 PM
dukeme's Avatar
dukeme
Default How to increase ?
How do you open up or get out the top of the gas filler? The pump size at the fuel station is bigger then the regular pumps. gas filler intake
Old Jul 29, 2007 | 01:00 PM
Tony71502's Avatar
Tony71502
Default RE: How to increase ?
Well i dont think you want to do that. The top that i believe you are referring to is the littleholeinside the gas filler pipe. Im pretty sure this whole top section is screwed into the body(inside the gas door cavity) and helps hold the pipe leading to the tank in place. I had to remove all this when dropping my fuel tank to replace pump. BUT, if i am wrong, then im pretty sure its just those 3 screws holding u back.
Old Jul 29, 2007 | 01:18 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Hmmmm, that's a federal offence there pal!!
Now how can that be. All unleaded nozzles are the same size.
Old Jul 29, 2007 | 01:24 PM
stang8689's Avatar
stang8689
go to a different gas station
Old Jul 29, 2007 | 02:28 PM
tmajikman's Avatar
tmajikman
Aren't diesel fuel nozzles larger than unleaded nozzles, I really hope you don't use the bigger nozzle if thats true.
Old Jul 29, 2007 | 02:54 PM
AndySpeed's Avatar
AndySpeed
ya dude you had to of went to a deisel pump... even dc in maryland has normal sized pump nozzles.. thats a big city.. im sure all citys are the came.. id say that was desiel pump lol...
Old Jul 29, 2007 | 03:08 PM
dukeme's Avatar
dukeme
You know....
Old Jul 29, 2007 | 03:10 PM
dukeme's Avatar
dukeme
The 110 octane is a larger pump
Old Jul 30, 2007 | 05:48 PM
Tony71502's Avatar
Tony71502
Use a funnel and gas can... simple solution.
Old Jul 30, 2007 | 05:58 PM
primetime5.0's Avatar
primetime5.0
ORIGINAL: dukeme
didnt you already do that once and you got a bunch of crap for it?
