90 5.0 engine probs.
Old Aug 6, 2007 | 10:21 AM
slicer4659's Avatar
slicer4659
Default 90 5.0 engine probs.
Hi All, havent posted in ages but I need some advice on my stangs problems. I've replaced the plugs,wires, rotor, cap, cleaned the maf, replaced the pvc, checked for vacum leaks, replaced the fuel filter, and the cars idle fluctuates as much as 400rpms, while cold, and after warming up the fluctuating drops to around 100-200 rpm's, and while going down the road, you can feel the problem is still there a little, but the only way to describe what it feels like going down the road is like someone grabbing your waistband and lightly jerking back on forth on ya. My plan is to give the car to my son as a graduation gift, but I want to make sure its running good 1st. I'd really appreciate any help guys. Thanks.
Brian
Old Aug 6, 2007 | 01:53 PM
creekrat's Avatar
creekrat
Default RE: 90 5.0 engine probs.
HA! sounds exactly like my problem!!!! I've been hunting down that dirty little gremlin bastard for months now! No one can seem to help track it down for me either! So, if you find that littl fu*ker somewhere, you let me know where he has been hiding!!! LOL
Oh, by the way , you shoulda posted this one in the tech section!
Old Aug 6, 2007 | 01:58 PM
85GTsleeper's Avatar
85GTsleeper
does the idle change just cruising in a straight line or while your using your brakes and turning ect.
Old Aug 6, 2007 | 02:49 PM
slicer4659's Avatar
slicer4659
It doesnt matter whether your goin around corners, straight line, braking or not, it's always there to some degree.
Old Aug 6, 2007 | 02:51 PM
slicer4659's Avatar
slicer4659
Will do creekrat, and like for you to ok. Stupid thing can drive ya nuts huh..... LOL !!!
Old Aug 7, 2007 | 12:25 PM
marcstang's Avatar
marcstang
I have the same problem with a carb 5.0 with 160,000 miles,I'm thinking timing chain slop, even though sitting still the timing lite doesn't seem to jump much.The search continues...
Old Aug 7, 2007 | 12:28 PM
TwotoneVert's Avatar
TwotoneVert
You didnt mention the EGR and IAC. Haveyou checked those?
Old Aug 7, 2007 | 12:29 PM
slicer4659's Avatar
slicer4659
LOL, you know, you'd think that with 3 people in two days with the same problem, that theres probably more out there that have had the same prob, and had it fixed and maybe have an answer for those of us that are still scratchin our heads....LOL !!!. good luck on yours marc.
Old Aug 7, 2007 | 01:51 PM
slicer4659's Avatar
slicer4659
Your right, I forgot to mention them, I did check them and they checked out fine. So the process continues.
Old Aug 7, 2007 | 01:59 PM
slicer4659's Avatar
slicer4659
Heres a couple more things I've noticed that are going on, starting to get a lot of misfiring, and when I took off the old dist cap, you could see where the rotor looks like it had been hitting the cap, not hard though, and the other day while warming it up, both the tach and amp guage simultaneously dropped quite a ways and then came back up, I'm starting to lean more towards an electrical issue maybe, the alternators new, and the amp guage while sitting in traffic you can watch it drop to about 8 volts, the battery is a 2 yar battery with 4 years on it, so I'll replace it and drag the multi meter out and see what the output is on the alt and the battery, thsi whole thing is driving me bonkers. I'll keep ya posted. Later
Brian
