Rear Disc Brake Conversion Done *PICS*
Old Aug 23, 2007 | 04:02 PM
absolutbspec's Avatar
absolutbspec
Default RE: Rear Disc Brake Conversion Done *PICS*
Yea im wondering about the rear too. I wrote a question about this yesterday without an answer. What do you mean you "bypassed the stock proportioning valve and joined the front brake lines" but you have a adjustable proportioning valve. What does bybassing it do?
Old Aug 23, 2007 | 07:30 PM
luckythirteen13's Avatar
luckythirteen13
ORIGINAL: shicaca
What are the benefits of doing this?
fox body brakes are a joke! the benefit is better braking
Old Aug 23, 2007 | 10:38 PM
88_cobra's Avatar
88_cobra
so what all did u need to do the rear??? the short ranger axles, then just the sn95 mounting plates, calipers, rotors, & dustshields???
i already had it converted to 5 lug drum using ranger axles and drums. i bought a kit made by ssbc that included the mounting brackets, dust sheilds, calipers and brackets, brake lines, ect. but yes u can use the parts off of the sn 95 rear but the axles are little bit longer so u need an offset wheel so use ranger axles
the stock proportiong valve on the fox it not set up for rear disc resulting in not enough pressure for rear disc, so u do away with the stock proportioning valve and use an adjustable proportioning valve for the rear brakes. mm sells the proportioning valve for like $45 and the kit to bypass the stock proportioning valve for like $20. i had to join the 2 front brake lines becuz the fox mc is a 3 port and the sn95 is a 2 port.
hope this helps
Old Aug 24, 2007 | 04:15 PM
absolutbspec
that definitely did thanks. now i can start mine in a few months after i get my axles from strange
Old Aug 25, 2007 | 05:29 PM
luckythirteen13
you said you have a master cylinder from a 95 mustang......is there a difference between 94 and 95 or are they the same? how much larger is it then the fox master cylinder?
Old Aug 25, 2007 | 08:53 PM
baggedb22's Avatar
baggedb22
do you have a picture of the axle in with just the mounting plate bolted to the rear??
Old Aug 26, 2007 | 12:39 AM
88_cobra's Avatar
88_cobra
the 95 and 94 are the same and i dont think they are bigger at all, same size just different. i think i might have a pic, i will check 2morrow and post it if i have it.
Old Aug 26, 2007 | 01:36 PM
TBird232ci's Avatar
TBird232ci
Could you get me some pictures of how you did the prop. valve bypass and the joining of the front brake lines? Ive never seen it done that way and it seems to be a much cleaner install that gutting the stock prop valve and adding an adjustable.
Old Aug 26, 2007 | 03:38 PM
jtmustang's Avatar
jtmustang
looks good i need to do the same with a little more suspension for my 347.
but looks good and u are ahead of me
Old Aug 26, 2007 | 08:57 PM
baggedb22's Avatar
baggedb22
also did u keep the quad shocks off???
