bouncy speedo
I heard there is a way to correct this...how so? mine isn't all over the place, but mostly from 0-35mph or so its bouncy if im accelerating slow(which i shouldn't be doing anyway right? lol) So how do I fix this problem?
if the odometer isn't working either it may have a broken cable and or come unplugged you'll have to remove the cluster = 20 min job and if it's still connected un connect it and start the car up with the speedo cable unplugged from the back and drive the car and see if the cable turns if it doesn't.... then there you have it the cable is broken or the drive gear is messed up....
ORIGINAL: mjr46
the cables just dont fall out of the cluster.
= speedometer portion
