Help my car is runninglike crap
Sep 20, 2007 | 07:46 AM
95 GT 5.0 spitting and sputtering. It was running great. I had a chip put in 2 months ago.Dont know if that may have something to do with it. Changed 02 sensor
Sep 20, 2007 | 07:51 AM
RE: Help my car is runninglike crap
need more info
Sep 20, 2007 | 07:53 AM
just at an idle? the idle air control unit seems to go out fairly easy. i.a.c. it can be cleaned, it messes with ur idle if its bad
Sep 20, 2007 | 08:07 AM
Idle is OK. It when you give it gas it runs rough.
Sep 20, 2007 | 08:09 AM
Could be vacuum leak, MAF sensor, salt & pepper shakers, etc. Did you try running it without the chip?
Sep 20, 2007 | 08:13 AM
what kind of "chip"?
Sep 20, 2007 | 08:42 AM
I got the chip at a FFW. I think it was from Dioblo motersports. I will try and take the chip out.
Sep 20, 2007 | 10:03 AM
sounds like timin maybe could be acouple of things needs a tune up,check fuel pressure,check your plugs wires timin could be alot check for codes
Sep 20, 2007 | 10:36 AM
Change your fuel filter if you havn't already.
Sep 21, 2007 | 07:14 AM
I took my chip out and my car is back to normal.
