roll cage
How fast are you planning on going? From 11.49 1/4 7.49 1/8 down to 9.99 1/4 6.39 1/8 all you need is a 6 point. Becareful buying one of the out of the catalog cages cause they are mild steel and heavy. Look at Wolfe racecraft's website. They sell chromoly kits that are notched and ready to weld. You will need to get it tigwelded though. This will be much lighter.
I would buy from someone other than duganracing. I had a issue with the owner about a car he was selling. I ran a carfax on it and it had info that he said was not true, i trusted the carfax and did not buy car. The odometer had been rolled back twice.
6 point are you sure? for some reason I thought u needed a 10 point for 11.49 or faster, must have read wrong... thanks for the info, well for now i have 422hp, eventually I will be getting a bigger block
Comp Engineering is going to be mild steel also. Are there any reputable race car shops around? It all depends on what you want to do and how much you have to spend. Are you going to weld it in yourself?
