Check oil light
Old Oct 7, 2007 | 10:52 PM
maiello2169's Avatar
maiello2169
Default Check oil light
So last week i noticed that my check oil light was on....so I checked my oil. for some reason it was above full....odd. well the car runs great, and there are no leaks or anything. Has anyone else had this problem before? BTW i have a 93 pretty much stock. Changed the oil about 1500 miles ago...running a k&n filter with motorcraft synthetic blend 10w30
Old Oct 7, 2007 | 10:53 PM
91hatchgt's Avatar
91hatchgt
Default RE: Check oil light
When you changed the oil how many quarts did you put in it? Don't know why the oil light would come on.. wierd.
Old Oct 8, 2007 | 12:23 AM
maiello2169
5...i've always put 5 and had no probs...could a sensor just be going bad?
Old Oct 8, 2007 | 01:12 AM
AdderMk2's Avatar
AdderMk2
Banned
above full? how far?
Old Oct 8, 2007 | 01:16 AM
maiello2169
about 3/4 of an inch....pretty high....
Old Oct 8, 2007 | 01:21 AM
AdderMk2's Avatar
AdderMk2
Banned
thats bad... you might wanna pull a drain plug and see if any coolant comes out.
and it would also be wise to drain some out anyway.... overfilling the crankcase is a good way to blow the motor
Old Oct 8, 2007 | 01:46 AM
maiello2169
yeah its pretty weird...do you usually use 5 quarts? anyway, i guess i'll let sum out. what happens if i see coolant in the oil? just curious.....
Old Oct 8, 2007 | 02:18 AM
91hatchgt's Avatar
91hatchgt
Yep.. 5 qts only (with factory pan), and make sure you always let it drain COMPLETELY.
Well if you have water in the oil, that's just not good. Probably a blown head gasket.
Fluid (such as water) in the oil will cause the reading on the dipstick to show above SAFE.
Old Oct 8, 2007 | 03:16 PM
maiello2169
god damn it...lol. i REALLY dont want to mess with the heads unless im gonna get some new ones. should I just compression test all of the cylinders first to see if i infact DO have a blown headgasket?
djbigskrilla
Sep 20, 2022 01:04 AM
J.casone400
Aug 28, 2015 09:33 PM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
