speed density cars
Old Oct 17, 2007 | 02:57 PM
Tim1970's Avatar
Tim1970
Default speed density cars
hello all i`m new to the site..i have the opportunity to purchase a 86 GT that has the speed density set up and i was told that these cars dont perform is this true? i dont wont to have to pull the harness out to put in a mass air set up..any help would be appreciated..
Old Oct 17, 2007 | 03:12 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: speed density cars
they make mass air conversions is one option ....they perform okay just not to cam changes that are overly aggressive and not designed for/with speed density in mind.......and or you could purchase a Megasquirt system that is made to tune speed density cars which will allow unlimited choice of mods for tuning to your liking......however the learning curve to operate such a system may not be within your realm of liking so a mass air conversion would be your simpilest solution
Old Oct 17, 2007 | 03:18 PM
Tim1970's Avatar
Tim1970
ugghh not good .. i dont really plan on going with that big of a cam..but i do want to use spray and some other bolt ons..im not sure what to do now..
Old Oct 17, 2007 | 03:20 PM
dimebag's Avatar
dimebag
god damn... speed density is NOT bad...
on the stock comp, w. out any real effort, you can make about 300 or so hp... because thats what 19lb injectors will support up to..
all u really have to do is watch ur cam choice
tuning is simple enough... timing, fuel pressure, cam timing, and for me, nitrous and fuel jets...
their easy to diag, easy to get a rough tune on your own, and stock for stock... their faster
but ****, put what ever heads, intake u want on it, and be careful of ur cam choice...
Old Oct 17, 2007 | 03:22 PM
dimebag's Avatar
dimebag
u wanna spray it? even better
here ya go... give me a goal... as far as 1/4 mile, and i betcha u can do it w. sd...
Old Oct 17, 2007 | 03:33 PM
Tim1970's Avatar
Tim1970
Ok.. i want mid to low 12`s ..using eldebrock intake..b303 cam? full exaust 3:73`s not sure on the heads..
Old Oct 17, 2007 | 10:37 PM
dimebag's Avatar
dimebag
well, no dice on the b cam...
mid low 12s...
intake(if u want that one, thats fine)
stock heads
crowner 11551 cam(speed density reacts well to this cam)
3.73 rear(or 4.10 with a 28inch tire... will turn out the same as 3.73s w. stock tires, but will hook a little better)
100-125 shot
some light suspension mods(mainly up front, for weight transfer, rear would be good to, but not mandatory)
and obviously a drag radial, or sticky tire
honesly, that should be high 11/low 12...
Old Oct 20, 2007 | 02:24 PM
atstark's Avatar
atstark
Have an '87 that was SD... love the MAF conversion. Cost me $300 in Ebay parts. Wiring tricky.. don't plan on driving too far in the first few days till you get the wiring right. Runs like a champ with a Cobra intke, BBK cold air and a E-303 cam.
Old Oct 20, 2007 | 02:31 PM
dimebag's Avatar
dimebag
****... **** your e cam... betcha my SD car is faster, lol
imo... i wouldnt have done the conversion, just to run an e cam....
Old Oct 20, 2007 | 02:32 PM
dimebag's Avatar
dimebag
im just ****in w. ya ofcourse
