Hood Install ?
Old Oct 19, 2007 | 05:36 PM
Gpony's Avatar
Gpony
Default Hood Install ?
I just picked up a truefiber 3in cowl.I cant get the thing to latch correctly. The first latch will set down,but the latch where you use the hood switch wont.
Any ideas?
The car didnt come with a functional hood.
Old Oct 19, 2007 | 05:51 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Hood Install ?
When I put my cervini's on, I had to raise the latching mechanism that is bolted on the front of the car. You'll probably have to do the same.
Old Oct 19, 2007 | 05:53 PM
Gpony's Avatar
Gpony
ill go give that a shot! Thnx
Old Oct 19, 2007 | 06:22 PM
Gpony's Avatar
Gpony
Did you drill new holes? Cuz i cant get it to move
Old Oct 19, 2007 | 06:39 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
No drilling, did you loosen the mounting bolts?
Old Oct 19, 2007 | 07:11 PM
Gpony's Avatar
Gpony
Sweet,thanks man,that was it.
Ive never seen one installed up close is there a lil more of a gap on the passenger side.It now locks securely so im cool with that
Old Oct 19, 2007 | 10:45 PM
91hatchgt's Avatar
91hatchgt
ORIGINAL: Gpony
You should be able to adjust it to even it out so that the gap is appx. the same on both sides.
Old Oct 20, 2007 | 08:59 PM
Gpony's Avatar
Gpony
ok,ill give it anothe shot lol thnx
Old Oct 20, 2007 | 10:01 PM
stang8689's Avatar
stang8689
Adjust the rubber stops
Old Oct 20, 2007 | 10:44 PM
ALMOST STOCK's Avatar
ALMOST STOCK
ORIGINAL: Gpony
Gap... higher or lower; adjust the rubber stops
Gap...wider or narrower; adjust the hinge at the hood
StalkerGT
Sep 25, 2015 02:41 PM
cbird1177711
Sep 2, 2015 04:12 PM
