subframe installation question..
Old Oct 22, 2007 | 02:31 PM
ponyboy302's Avatar
ponyboy302
Default subframe installation question..
whats happening fellas .. well i just received my mm xl full length subframe connectors .. someone had mentioned to me it would be a good time to install new springs ... just curious what is the purpose of having the wheels up on a lift while installing these things(no im not about to attempt it myself just curious )is it to compress the springs ?? do i have to install new springs or is it ok if i do it sometime down the road .. does it matter ???
btw i have a 93 stock hatch 5.0
Old Oct 22, 2007 | 02:39 PM
blk40th's Avatar
blk40th
Default RE: subframe installation question..
the springs in there are fine u just need the car on level surface with all the load on it so the frame stays straight.
Old Oct 22, 2007 | 03:36 PM
bighungrymatt's Avatar
bighungrymatt
I just put my car on blocks when I welded my subframe connectors in
Old Oct 22, 2007 | 05:25 PM
OnyxCobra's Avatar
OnyxCobra
Springs should have no affect on the subframe install, but ideally you want the car on a drive on lift so the weight of the car is sitting like it does on the road. Lifting the car by the frame can cause the chassis to flex and be welded crooked. People have had problems closing their doors after such installations.
Old Oct 22, 2007 | 11:30 PM
jtmustang's Avatar
jtmustang
sorry to hijack the thread as i too just received my upr full lengths and i was holding them up tonite and it looks likeu have move or remove the fuel lines to weld them up any info what did u guys do that have them
Old Oct 22, 2007 | 11:41 PM
bighungrymatt
I pulled the grommets out and wrapped the fuel line with a wet towel
Old Oct 23, 2007 | 12:55 AM
jtmustang's Avatar
jtmustang
ORIGINAL: bighungrymatt
cool is that what everybody else do just curious
Old Oct 23, 2007 | 01:30 AM
OnyxCobra's Avatar
OnyxCobra
I just unbolted the close lines and moved them out of the way a lil bit, no big deal.
Old Oct 23, 2007 | 09:59 AM
bighungrymatt
yeah just take your time, shouldnt be a problem
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
Sep 8, 2015 11:50 AM
