POSSIBLE COMPUTER PROBLEM
Old Oct 26, 2007 | 03:54 PM
met6265's Avatar
met6265
Default POSSIBLE COMPUTER PROBLEM
RECENTLY HAD A 1800 T0 2200 STAHL TORQUE CONVERTER INSTALLED, CAR WILL NOT HOLD IDLE FOR FIRST TWENTY MINUTES, AFTERWARDS NO PROBLEM, BUT THIS HAPPENS EVERYTIME THE CAR IS RESTARTED, I DO KNOW THEY DISCONECTED THE BATTERY, BUT SHOULDNT THE COMPUTER ADJUST AND RESET AFTER 20 TO 30 MINUTES OF DRIVING. ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED
Old Oct 26, 2007 | 03:55 PM
ctgreddy's Avatar
ctgreddy
Default RE: POSSIBLE COMPUTER PROBLEM
i didnt know stahl converters affected your idle like that.
Old Oct 26, 2007 | 04:05 PM
met6265's Avatar
met6265
I DONT BELIEVE ITS THE STAHL CONVERTER CAUSING THE ISSUE, WHEN THEY DISCONNECTED THE BATTERY THE COMPUTER WILL READJUST TO ANY CHANGES WHEN RECONNECTED AND STARTED IN ABOUT TWENTY MINUTES OF DRIVE TIME, AS SO IVE BEEN TOLD, BUT THE COMPUTER IS NOT SINKING ITSELF GOES THRU READJUSTMENT EVERYTIME THE VEHICLE IS STARTED
Old Oct 26, 2007 | 04:50 PM
uedlose's Avatar
uedlose
did you try to reset the idle? as far as the computer resetting it self every time check to see if it has a hot to the computer keep alive memory. may be they pulled a wire lose some where pulling the trans out.
Old Oct 26, 2007 | 04:58 PM
met6265's Avatar
met6265
THANKS FOR INFO WILL CHECK FOR LOOSE OR CUT WIRES, THE IDLE FLUCTUATES BETWEEN 200 TO 900 WHEN IT BOUNCES BACK DOWN THE CAR STAHLS, IT WILL KEEP BOUNCING AND STAHLING UNLESS I RIDE THE BRAKE AND GAS PEDAL TO KEEP RUNNING.
Old Oct 26, 2007 | 05:43 PM
AdderMk2's Avatar
AdderMk2
Banned
the computer will not re-adjust itself in 20-30 minutes..it could take days, or even weeks.. depending on how long it had been adjusting itself previously.
and for the love of god man... STOP THE FRIGGIN CAPS!
Old Oct 26, 2007 | 05:50 PM
met6265's Avatar
met6265
any reason why this may take so long, i am also changing out the throttle body and maf, and cai and have been advised to have my computer reprogrammed after these changes, is this info correct, due to the person at turbo tune wants 300.00 to reprogram the computer
jma2
Jul 10, 2023 01:00 AM
EZFEED
May 5, 2016 08:54 PM
firecoyote
Sep 27, 2015 02:37 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
