429/460 SN95
Mach I Section Moderator
i have read a ton of posts of people starting to do this , but i was wondering if anyone has pics/ videos of their BB SN95, and what does this engine plate do?, i know there is a **** ton of fox's that have it done, but i want to have something diffrent, so i'm looking to do this slowly. here's the plan for it
Stage 1 (3-6 months)
buy a 94-98 gt/ sixxer- doesnt matter if it runs ( no more than $1k)
pull out the old engine and sell ( $500 for the Motor gt,$ 250 for the sixxer)
pull the tranny ( auto= $400 manual = $550)
pull the rear end ( replace witha built 8.8)
pull all the wiring for fuel injection out
Stage 2 (6-9 months)
buy a 429/460 out of the junk yard w/ c6 ($500)
buy the tubular k member ( $250)
buy conversion kit from summit/ jegs ($900)
buy holley 870 CFM ( $400)
buy upgraded fuel system ( i have no idea i need help on this.)
buy big cam (i need help here too guessing $300)
aluminum heads (used i found a set on ebay for $800)
Stage 3 (1 month)
Installation time shouldnt take more than a couple weeks on and off.
Stage 3 (1 month)
So, whats the question? There's an sn95 with a 460 at http://fordifiedracing.homestead.com/bigblockfox.htmlon the front page towards the bottom.
Here's one too
http://www.cardomain.com/ride/660941
same car
http://new.photos.yahoo.com/bigbronc...60762313251906
Another
http://alliesautomotive.com/katofamilyracing.html
Here's one too
same car
Another
a block plate is used in conjunction with the motor mounts. generally cars that use a block plate, i've always heard it called a engine plate and hopefully we're talkin bout the same thing, are makin big power. its to aid in keeping the engine securly mounted to the frame/car. or at least thats my understanding so somebody chime in if im off
If you're talking motor plates, thats what I have in my 68. Use a front and mid mount and then the trans crossmember. You also need limiters to stop front to back movement.
http://members.***.net/darkknight102/pics%20029.jpg
http://www.mysticspeed.com/68chassis...33-68nwfrt.jpg
do my prices look right, and could i make it handle for road races. what kind of power am i looking at? what kind of prep do i need to do to the sn95?
well the type of suspension you put in there will depend on your intentions with the car. do you want it to be a drag car, road race, or just a general street bruiser? and if you just want it for the street, which one of the other options would be more important than the other.
