What did yall get your stangs for when you bought them?
#61
RE: What did yall get your stangs for when you bought them?
I bought mine in 99' with 97,000 miles. Interior was in perfect condition, the drivers door was dented from a deer running into it. It was absolutely stock right down to the Motorcraft air filter and Pep Boys replacment mufflers.
Mods:
DSS 331 10.89:1 compression/AFR 165 heads/ DSS rockers/Comp XE274 cam
Trick Flow track heat intake/FRPP 65mm throttle body/ C&L 76mm mass air meter
Aeromotive FRP/ BBK 190 pump/ FRPP 24lb injectors (ordered 30s)
Astro super T5 gears/G Force output shaft/ Steeda shifter/ Ram clutch/FRPP aluminum driveshaft
Moser 33 spline axles/ Eaton/ 4.10 gears
Becool radiator/ electric fan/ battery relocated to rear Taylor aluminum box
UPR upper & lower pro series control arms/ Strange sturts/ QA1 rear shocks/ Eibach springs
homemade frame connectors/ Weld Draglites/ Nitto drag radials
Mods:
#63
i bought my 86 gt vert brand new from pasadena ford in so. cal. $17,000.00 out the door. no engine mods. only an msd 6a box
strut tower support
g-load brace
full length sfc cross barred into rollbar
ford "c" springs (rear dead coil removed. 1/2 coil cut in front)
kyb shocks/struts/quads
torquebox reinforcement kit
poly-urethane bushings all around
6 pt. rollbar (removed temporarily for interior restoration)
corbeau gt2 seats
diest 5 pt. racing harness
strut tower support
g-load brace
corbeau gt2 seats
#64
1500 for my 86. needs paint though. and interior work. mods in sig.
But it had a brand new engine in it.
Edit: ok no mods in sig. i will post later
#65
I bought my 95 GT bone stock w/67,000 miles for $3500. The car was in excellent shape and still is with 95,000 miles. I bought it in 04 when I was 14. Taught piano lessons for four years and saved every penny I had for it.
Since then I've added pretty much every part available that I could.
#68
paid 3k for the car last year. so far have over 9k invested not including the purchase price. and look where i'm at
Motor
-Fordstrokers.com 347 stroker, 10.5 cr, forged rods/pistons, cast crank
-Canfield 195 aluminum heads
-Holley systemax intake
-CI cam, 114 lsa, .592/.600 lift
-Livernois motorsports dyno tune
Air/fuel/spark/exhaust
-Ebay cai w/ k&n
-Pmas maf
-FRPP 30# injectors
-Walbro 255 pump
-Accufab fuel pressure regulator
-FRPP wires
-Autolight 24 plugs
-Crane Fireball coil
-Accel cap and rotor
-BBK equal length chrome headers
-BBK o/r hpipe
-Flowmaster catback
drivetrain/suspension
-Aode w/ transgo shift kit
-B&M tranny cooler
-Edge racing 3k stall converter
-FRPP aluminum shaft
-FRPP 4.10's
-Explorer 31 spline trac lock
-Yukon 31 spline axles
-Lakewood 50/50 rear shocks
-Mac u/l control arms
-Custom subframe connectors
Body/Wheels&tires/Other
-New ford bumper
-96 style tails
-Rear bumper letter inserts
-AVS headlight covers
-5% tint
-Rear "FORD" window vinyl
-Front "stroked and poked" vinyl
-96 style gt wheels
-Ebay white face gauges
-Painted interior trim
-Autometer trans temp/water temp/air/fuel ratio gauges on apillar
-Autometer Fuel pressure/Oil pressure mounted on windshield cowl
after its running again the only thing i'll be doing to it is putting in a 6pt cage, drag radials/prostars, and a little giggle gas.
Motor
-Ebay cai w/ k&n
-Pmas maf
-FRPP 30# injectors
-Walbro 255 pump
-FRPP wires
-Autolight 24 plugs
-BBK o/r hpipe
-Flowmaster catback
-B&M tranny cooler
-FRPP 4.10's
-New ford bumper
-96 style tails
-5% tint
-96 style gt wheels
#69
well this is my 87 that i gave 700 dollars for it back in august.it used to be a 4cylinder automatic car and was changed to a 302 5 speed.it had the 7.5 rear end in it when i got it and i bought an 8.8 from one of my friends out of his 89for 100 dollars.
#70
