Typoon intake questions
When it come to intakes i pretty much made up my mind that i want the holley but the typoon looks super sexy and is alot cheaper. i was woundering how it compared with the others. i know that someone has posted a flow chart with different intakes but i cannot find it
i forgot to mention that heads are not an opion in the near future and this car will be street driven.
I got it and it works just fine. Just get a dremel and clean the ports up a tad. Thats it. I compared it with an edelbrock and didn't see that much of a difference to warrant the extra $250~
i took about 2 hours out of my life to port out the intake to the exact dimensions of the eddy RPMII intake. at work i have a dyno sheet of a 5 liter with a typhoon intake only, the rest is stock. he had a 14hp gain which i guess isnt that bad considering he used it out of the box and with stock heads. personally i dont see a reason to spend the extra 250 bucks if you have access to a die grinder and two hours of time.
ORIGINAL: blk40th
will porting it really help pick up a little power?
also for those of you who have the typhoon. did you check your thermostat port before you installed it? i had to hone that out as well. it wasnt even close to a circle. also i smoothed out the TB intakepassage so thats nice and round. then, (and i really suggest this) took a flapper wheel and sanded the entire runner and made it smooth as hell. this should deff help flow!
