newbie question
Old Nov 3, 2007 | 03:19 PM
FredP's Avatar
FredP
Default newbie question
i know 50's are well known for having idle issues lately my cars been reving up to 2k and i know theres a leak either in my vac lines or intake but.... iono what are vac lines or how to check for leaks any suggestions?
Old Nov 3, 2007 | 04:33 PM
92gtafr205's Avatar
92gtafr205
Default RE: newbie question
this could also be the tps, needs to be set under 1 volt like .98 .99 if this is out the car will idle up and down an sometimes stall this is on top of the thottle body 2 srews need a multimeter to ckeck
Old Nov 3, 2007 | 04:42 PM
86GreenMachine's Avatar
86GreenMachine
spry carb cleaner where you think your vaccum leaks are when the car is running.The idle will change if there is a leak!
Old May 11, 2008 | 09:48 AM
sYckmYnded's Avatar
sYckmYnded
I ♥ Acer
sounds like vacuum
Old May 11, 2008 | 10:43 PM
xxxx89gtstangxxxx's Avatar
xxxx89gtstangxxxx
Don't feel alone man I'm going through the exact same problem!!!!!!! I changed my tps and it helped but didn't solve the problem I'll hook up a meter and check that I haven't done that yet I'll let you know how it goes
Old May 11, 2008 | 10:53 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
quickest way is take it to a shop that has a smoke machine
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
