HO vs. NON HO
Old Nov 9, 2007 | 03:38 PM
19stang86's Avatar
19stang86
Default HO vs. NON HO
my buddy found a 1986 lx with 120k on it but its a non HO.Its a hell of a deal for $3500 (granny car) very clean. But he is leaning to the no side because the firing order is not an HO firing order so were guessing its not an HO. but its there a big difference in power between the 2? Any info will help hes trying to get it this weekend but this is holding him back
Old Nov 9, 2007 | 03:53 PM
91hatchgt's Avatar
91hatchgt
Default RE: HO vs. NON HO
Yes there is a big power diff between the H.O. and non-H.O. the 86 should be an H.O. however as long as it is the original engine.
Old Nov 9, 2007 | 04:05 PM
86 5.0L's Avatar
86 5.0L
big difference aout 80 HP lets see 225 HP for 87-92 HOs, an 86 302made about 150HP eh close enough, now heres the thing if you're keeping it stock then dont get it but all it needs is a simple cam swap and its a HO
Old Nov 9, 2007 | 04:12 PM
Merle's Avatar
Merle
There are several differences in the motors depending on the year. All V-8 Mustangs came with HO engines. Depending on the year of the motor that was put in, it may not have a double roller timing chain, it may not have roller lifters. It definitely won't have the HO cam. It wont have the stronger crank, or the hyperutectic pistons. The heads will probably be different also.
Old Nov 9, 2007 | 04:23 PM
86 5.0L's Avatar
86 5.0L
^ thats true, you'll need to find what engine it came out of
Old Nov 11, 2007 | 01:16 PM
19stang86's Avatar
19stang86
BUT i was told that you cant put a different cam due to flat top pistons,
Old Nov 11, 2007 | 01:29 PM
86GreenMachine's Avatar
86GreenMachine
i have the flat top pistons in my 86 and its an HO.Its got alot of torque for being stock to.273 rwt & 190rwhp.But you do have to watch what cam you put in there if it its an aftermarket cam.A stock HO cam should work as long as its the right cam for the type of lifters you have in the engine now
Old Nov 11, 2007 | 01:37 PM
19stang86's Avatar
19stang86
How could i tell what engine is in it. And 86green what cam do you have?
Old Nov 11, 2007 | 01:55 PM
86GreenMachine
Its a stock 86 HOhydrolic cam.( dont mind the spelling)
Old Nov 11, 2007 | 02:10 PM
86 5.0L's Avatar
86 5.0L
ORIGINAL: 19stang86
that is correct for aftermarket cams with extra lift then stock, I have flattop pistons also, just stick in the 86 HO cam, change the firing order and voila, you got an HO
