viper motor in a fox?
Old Nov 11, 2007 | 02:06 AM
Stanger89's Avatar
Stanger89
Default RE: viper motor in a fox?
I would love to have any car with a viper engine in it!
Hey, I got an 85 RX-7...[sm=gears.gif]
Old Nov 11, 2007 | 10:44 AM
aode08's Avatar
aode08
The engine has to sit low.
If you look at one underneath, youll find yourself needing to modify your cowl tunnel , frame and K member EXTENSIVELY. And run a whole custom suspension.
If you have those types of metal fabrication skills, go work for a construction company and get $$$$$$$$$.
Ive seen quite a few guys on here with decent welding and fabrication skills. There is alot of cash in that.
Old Nov 11, 2007 | 11:33 AM
stang8689's Avatar
stang8689
Anything is possible, i would stick to Ford engines
Old Nov 11, 2007 | 12:04 PM
irish1's Avatar
irish1
For the kind of money it would take, I would build a hellacious 351W or 351C stroker, pair it with a nice TKO600, get the car painted and put nice rims/tires/suspension on it. Then go on vacation and still be money ahead.....maybe a slight exxageration, but not by much.
Old Nov 11, 2007 | 03:08 PM
tooslow5.0's Avatar
tooslow5.0
ORIGINAL: dangstang92
Yeah, saw a V10 SN95 on TV years ago, think it was on Horsepower TV or one of those weekend car shows. It was a test mule of some sort, for a Shelby or Cobra that was obviously never built. In fact I think Carroll was driving it.
I remember they did a break stand with it and the front brakes couldn't hold the car back. Front brakes were locked and the car was still pushing forward at a fast rate with the rear tires up in smoke....crazy!
it was actually a episode of "rides". i have the box set, and that was one of my favorite episodes. they were testing the v10 in the sn95 to see how it would run in the shelby cobra concept. that burnout shot was sweet the way it pre-loaded te suspension and the whole *** end raised up about5 inches. i was like "oh my gawd"[:-]
Old Nov 11, 2007 | 03:45 PM
Riceinator's Avatar
Riceinator
is this it?
http://www.youtube.com/watch?v=m6eSBLY5pIA
Old Nov 11, 2007 | 04:21 PM
19stang86's Avatar
19stang86
I WOULD JUST BUY A VIPER AND KEEP MY FOX!! SAW ONE ON EBAY FOR 47K, YOU WOULD SPEND THAT BY THE TIME YOU GOT FINISHED WITH THE STANG
Old Nov 11, 2007 | 04:43 PM
ih8chevy's Avatar
ih8chevy
puttin a viper v10 is quite possibly the stupidest thing u could do, no wait u could put a chevy or a honda motor that might be worse, but the v10 is not a good engine, and for the money you could build a 1000 hp bbf and a 200 shot and still have money to spend on hookers or something.
Old Nov 11, 2007 | 05:43 PM
TAPOUT's Avatar
TAPOUT
ORIGINAL: cylostang
why would you violate a perfectly good fox with a dodge engine? use the ford v-10 and so what if it shoots spark plugs outa the heads. besides that you wont be able to make any turn at more than 10mph. well to each his own and if yah do happen to do it put a vid on Youtube id love to see it.
Why would you put a perfectly good Dodge V-10 in a Ford?
Old Nov 11, 2007 | 05:48 PM
F250sd's Avatar
F250sd
ORIGINAL: ih8chevy
Actually, the Viper V10 is a great engine. Would throw a fox around quite well, and still be a relyable, streetable engine. Heck, a 500hp NA windsor motor is really pushing streetability.
As to the engine weight thing, the Viper engine is somewhere int he neighborhood of 500 pounds, since it has aluminum heads and block that is wayyyyy less then the Modular V10, and actually right around the windsor in weight, and probably still less than a 5.4l mod motor.
What you really need to think about, are the hassles of putting a Viper V10 in a fox worth the end result? I think it would make for a very unique car,
one that would be hella fast.
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
logan409
Sep 26, 2015 07:43 PM
