95 gt stumbling throttle
i have a 95 gt that when the car is throttled the engine stumbles and has trouble running up in the rpms. what would be the common items that i would need to check to correct this problem? thanks
i have a 95 to and mine did the same thing...the plug that goes in for the timing by the intake was out on mine...check to see if yours is in, does it backfire in the intake when you give it gas??? mine did that too..
the plug you pull out for setting the timming on the motor, its on the same harness as the mass air and and stuff, its normally grey and about 1 in by a 1/2 in, let me know if you find it if not i will find a link to send you...
ORIGINAL: jnsnams
exactly, and thank you 91hatchgt, i played around for about a month trying to figure it out on mine before i found the plug under the car in the garage and went looking to see where it went...when i found out it worked perfect from that point forward...
