wooooohooo
Old Nov 13, 2007 | 01:39 PM
stangman94's Avatar
stangman94
Default wooooohooo
My car dynoed at 254 and 310 torques or something like that. I threw out my dyno sheet cause I was mad so dont ask to see it.
I think I found my problem though. I have had a light tick on my head for a while and I never thought much of it becuase I called trickflow and they said it was normal for the older generation heads But today I took a stethascope and listend to all mycylinders from the top of the valve covers and from the ones I could reach I put the stethascope up against the head too. They all sounded perfectand their was no tick except the when I put the scope above the #1 cylinder and when I put the scope on the head right above the spark plug it did not sound good at all. I dont know that much about heads but I am guessing it is a bad exhaust or intake valve since I just replaced all my lifters. I am happy nowGood Rant over
Old Nov 13, 2007 | 02:36 PM
jtmustang's Avatar
jtmustang
Default RE: wooooohooo
what did u do for a h/c/i ?
Old Nov 13, 2007 | 03:13 PM
bighungrymatt's Avatar
bighungrymatt
nice, if you are excited why did you toss your dyno sheet haha
Old Nov 13, 2007 | 04:30 PM
stangman94's Avatar
stangman94
I tossed my dyno sheet cause I though that the tick was normal and so thats all my car made working 100% but now that I am 99% sure I have a bad head valve that means it would of dynoed higher. SO I= HAPPY its an aode too.
Mods are
Trickflow heads bought used and the (exhaust is ported a little)
Trickflow street heat manifold
Steeda #19
full exhaust upgraded fuel system 70mm tb 75mm mafetc.
Old Nov 13, 2007 | 11:46 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: stangman94
I wouldn't be so sure about that fella!!!!......If you had a bad exhaust valve and or intake valve...this would result in a loss of compression and if it were hanging up in the guide not allowing it to seat properly it may tick if the valve train were set up with a valve not fully seated and when it frees up the rocker would be out of adjustment.........I'd lean more towards a rocker out of adjustment and or a broken valve spring........ valves out of adjustment meaning set to loose will open late , close early and reduce flow and overlap......and cause a noisy valvetrain........so if you have a smooth idle then I'd rule out a burnt or bent valve because that would cause loss of compression and a cylinder would not fire properly
