AOD Kickdown Adjustment
Old Nov 16, 2007 | 02:51 PM
Hawaii 93 Stang's Avatar
Hawaii 93 Stang
Default AOD Kickdown Adjustment
I need help!!! The kickdown cable came off the throttle linkage(the rubber gromet finally cracked) so my mechanic put a lock washer and it'sre-attached. But now the tranny is not shifting if I leave it in OD. But does shift from a dead stop in D-1,2, & 3. But when you shift it to 4th, it is like it's not in gear. So how do I adjust the kickdown???? Thanks guys!!
Old Nov 16, 2007 | 04:27 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: AOD Kickdown Adjustment
you go buy a new part.....meaning the one that broke...you have someone do a half ace repair....you get half ace results...that's just the way it is[&:]
Old Nov 16, 2007 | 04:46 PM
Hawaii 93 Stang
Thanks. It's just a temp job til I find a new cable. The 3 local Ford dealers in Hawaii don't have them and Ford does not make them anymore. So Iam searching for a new one. You have to buy the whole cable to get the new end that connects to the linkage. But, yeah I agree with you, don't like doing things half a@#
Old Nov 16, 2007 | 04:58 PM
98MustangGT46's Avatar
98MustangGT46
Mine broke awhile back. I went to ford and got one and i also made sure i stocked up considering there cheap enough. So now if it happens im all set no matter where i am.
Old Nov 16, 2007 | 05:11 PM
Hawaii 93 Stang
Yup, they stopped making it last year.
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
