help!
Old Nov 26, 2007 | 04:06 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: help!
I thought that's how most people did it? I think the problem is it's a DSM, try it with the Stang
Old Nov 26, 2007 | 04:08 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: help!
ORIGINAL: FastFordSVO
Hey guys, I've got a 91 2.0 turbo eclipse. I've had an intake and exhaust for a while and wanted to get more performance. I was recommended to port and polish the intake and exhaust. We found out they used abrasive material to do it like gritty sand. So I got with my friend that tunes Hondas and we decided to try it ourselves. We got a bag of sandblasting sand and hooked up into the intake and started the car. We had to hold the gas so it would run. He wanted to let the engine suck in the sand through the intake so it would port it out and then push it out the ehxaust so it would port the exhaust manifold.
I was worried that it might cause problems but he figured it'd be OK as long as we didn't make boost and it get sucked in the turbo. After running the car and letting it suck in sand we got about half way through a 25 lb bag. The check engine light was on and the engine was bucking and kicking and sounding really weird. We stopped and hooked the car back up normal and took off the sand supply. We tried to start it again and it was really hard. Once started it couldn't idle and kept making weird noises. We took it out and drove it and it started to make scraping and knocking noises.
Help! Can anyone tell me what to do! My buddy only does Hondas so he doesn't know much about DSM’s.
almost as good as the MR Nieb and the water hose to flush the oil system....similar parrallel here[&:]
Old Nov 26, 2007 | 04:11 PM
FastFordSVO's Avatar
FastFordSVO
Default RE: help!
ORIGINAL: mjr46
oh lord! hahahahaglad you enjoyed it!
Old Nov 26, 2007 | 04:57 PM
1985stang's Avatar
1985stang
Default RE: help!
Let's make sure that everyone knows you shouldn't do this to port your intake . Something like this is howNieb got his brilliant idea.
Old Nov 26, 2007 | 08:42 PM
98MustangGT46's Avatar
98MustangGT46
Default RE: help!
ORIGINAL: 1985stang
lol... +1 on that.
Old Nov 26, 2007 | 09:12 PM
CBurn's Avatar
CBurn
Default RE: help!
GWAHAHAHAHA
OH MAN
what a retard
if you click the link and read a couple of posts down
he's like "i gatta pick up my girlfriend from work. Can i drive it?"
GHWAHAHAHAHAHA
Old Nov 26, 2007 | 09:44 PM
95vertGTS's Avatar
95vertGTS
Default RE: help!
That was almost as good as the kid thinking about bypassing a turbo and running his exhaust straight to his intake, on his corvette.
