? About bolting block on engine stand
Old Nov 30, 2007 | 05:51 PM
ret27m's Avatar
ret27m
Default ? About bolting block on engine stand
[/align]I am getting ready to get a used 1995 5.0L HO motor delivered monday, I have a 1000lb universal engine stand and I need to know what size bolts to use to bolt the block to the standplate, I was told by someone that they thought 7/16 coarse thread and 3" long would do it. I picked up 4 of them today and the length seems perfect but is the 7/16 coarse thread correct....Thanks Jim
Old Nov 30, 2007 | 06:28 PM
87lxBlackWidow's Avatar
87lxBlackWidow
Default RE: ? About bolting block on engine stand
i dont know the exact thread or pitch but its the same as a head bolt. I have 3 block in my garage being held up by head bolts. use the lower head bolts and you should have no problems.
Old Nov 30, 2007 | 07:48 PM
gothand's Avatar
gothand
7/16"-14 bolts is what you need. My engine stand requires 4" long bolts and every engine stand I've seen is basically the same, so I think you may need longer bolts. Better a little long than short! (that's what she said )
Good luck!
Jeff
Old Nov 30, 2007 | 09:03 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I use a old set of chevy head bolts!!!! I always knew a chevy was good for something!!!
Old Dec 1, 2007 | 12:36 AM
w8less's Avatar
w8less
i just did that today. 7/16 and they were 3.5in and i used one washer for each bolt
Old Dec 1, 2007 | 05:42 AM
ret27m's Avatar
ret27m
Thanks everyone, I only have one shot to get the motor on the stand with the delivery guy and I want everything right. I cant wait to start this winter project.
Old Dec 1, 2007 | 05:56 PM
irish1's Avatar
irish1
You can always ask a friend to come over and help later, also useless trivia, some engine builders will not build an engine on a stand, only on the ground. I used a stand myself and bolted a 1000 lb electric winch to my garage ceiling beams so I can yank an engine anytime I need to, by myself. Cost me 60 bucks plus 12 for the long bolts.
Old Dec 1, 2007 | 09:11 PM
w8less's Avatar
w8less
ORIGINAL: irish1
that is true they also recommend engine cradles
Old Dec 1, 2007 | 09:25 PM
tinman's Avatar
tinman
I've read someplace about the later thin-wall blocks taking a 'set' to them when left on an engine stand for a long time.
THEY SEEM TO BEND BY THEMSELVES....
Hard to believe but metal can be strange.
From what I understand, the bending will have affect on the main bearing alingnment.....
P51_GT
ROUSH Performance
24
Apr 6, 2019 09:19 PM
msavoia23
12
Jul 7, 2018 12:08 PM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
Gary Ugarek
Aug 26, 2015 08:41 AM
