Radio
Old Dec 23, 2007 | 02:01 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Radio
ORIGINAL: 86_GT_Mustang
ok dosent work on the red at all key on or off.
Do you have a test light to be sure there is power.
Old Dec 23, 2007 | 02:02 PM
86_GT_Mustang's Avatar
86_GT_Mustang
Default RE: Radio
ORIGINAL: PRO50SC
Wount the radio no work at all if there is no power?
Old Dec 23, 2007 | 02:04 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Radio
ORIGINAL: PRO50SC
That is correct. So you need to know if the circuit you are now connecting the red wire to is live w/ the key on, hence the question about the test light.
Old Dec 23, 2007 | 02:19 PM
86_GT_Mustang
Default RE: Radio
But it works connected with yellow...
Will a volt meter do? i cant find my test.
Old Dec 23, 2007 | 02:23 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Radio
Yeah, that will work. What do the directions say for the wiring.
Old Dec 23, 2007 | 02:29 PM
86_GT_Mustang
Default RE: Radio
put it to the right speaker..
its a dashboard light dimmer switch im having problems with it wount turn on without that hooked up and when it hooked up to yellow stays on and red dosent work.
when i put the voltmeter to yellow for - and red + it reads 0
Old Dec 23, 2007 | 02:38 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Radio
Your not supposed to go across the yellow and the red, they are separate circuits.
Old Dec 23, 2007 | 02:39 PM
86_GT_Mustang
Default RE: Radio
ORIGINAL: PRO50SC
im not good with wiring.
Where do i ground it to then?
Old Dec 23, 2007 | 02:44 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Radio
Ok, normally after market stereos are wired like this
Speaker harness, self explanitory
Yellow, to a constant powered 12 volt sorce
Red, to a key activated powered source
Black, to a ground. Somethging solid under the dash
Then there will be a couple othe colors to trigger a power antenna and an amp.
Do you have instructions w/ the stereo?
Old Dec 23, 2007 | 02:48 PM
86_GT_Mustang
Default RE: Radio
ORIGINAL: PRO50SC
Speaker harness Good.
yellow to constant.
red to red.
black grounded.
atenna nothin.
there is a daskboard one that the radio wont work unless hooked up to some power.
