Cam ? edited
Old Dec 28, 2007 | 12:40 AM
88stang302's Avatar
88stang302
Default Cam ? edited
looking at crower cam 15512 496/512 lift and and 222 on the intake side and 228 duration on exhaust side would this be a safe cam to put on a stock 302 with stock headswill it clear piston 2 valve wise.. ok change that im going get a set of heads 2 i already have a good intake i brought when i did the carb swap its a edelbrock and is good up to 6,000 and this cam is good from 2,000 to 6,000 what kind of head do yall suggest what about gt40 heads
Old Dec 28, 2007 | 01:54 AM
TTGreenSN95's Avatar
TTGreenSN95
Default RE: Cam ?
Its pretty close to my cam I have the tfs stage one 4.99I 5.11E
Mine clears with 1.6 rockers and gt 40 p heads and my exhuast valve is a bit bigger than stock. even so you should always check clearance blah blah blah........
That cam should love nitrous!!!!!!!
Old Dec 28, 2007 | 06:17 AM
OnyxCobra's Avatar
OnyxCobra
Default RE: Cam ?
It is a pointless mod with stock heads, save ur money
Old Dec 28, 2007 | 07:13 AM
92cobra's Avatar
92cobra
Default RE: Cam ?
+1 on that ry, if you dont have supporting mods its not worth it.
Old Dec 28, 2007 | 11:28 AM
GT350's Avatar
GT350
Default RE: Cam ?
To answer, yes its fine on all clearances, and it will make around 285HP at the crank. It will sound nice also.Its better than stock, so do it!
Old Dec 28, 2007 | 11:51 AM
WhiteWindsor's Avatar
WhiteWindsor
Default RE: Cam ?
ORIGINAL: GT350
How do you come up with 60 extra hp at the crank with just cam and no supporting mods?
The stock cam on the fox's are pretty good with the stock heads. I've seen plenty of cars slow down by changing JUST the cam on stock engine just so it will sound better.
Old Dec 28, 2007 | 12:06 PM
88stang302's Avatar
88stang302
Default RE: Cam ?
ok im going to get some heads to any suggestions
Old Dec 28, 2007 | 04:16 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: Cam ?
ORIGINAL: 88stang302
what's your budget? GT40s, AFRs, Canfield, Brodix, RHS, Patriot, Trickflow, Edelbrock, etc. They're all good heads and will make a lot more power than your stock ones, depends how much you want to spend though.
Old Dec 28, 2007 | 04:41 PM
88stang302's Avatar
88stang302
Default RE: Cam ?
ORIGINAL: OnyxCobra
yea im a on buget i head something like u can get gt40 heads of a 5.0 ford explore is that true
Old Dec 28, 2007 | 04:51 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: Cam ?
Yeah they are GT40P heads and require special headers for the most part, i believe the GT40s are still better.
