trans problem
Old Dec 29, 2007 | 11:48 AM
95greengt's Avatar
95greengt
Default trans problem
ok ive gota 95 gt with and aode trans and ive got a vibration when it shifts i replace the mount cause it had a broken bolt and that didnt fix it while under the car i noticed that my driveshaft it pretty loose in the tailshaft you can move it up and down about 2-3 mm is there a bushing or bearing in the tailshaft which i need to replace and if so how hard is it to replace. also when i replaced the u joints the guys at the parts store first gave me a set for an automatic which mine is they were to small so i took one back with me and the guy said the ones i had are for a 5sp could someone have installed the wrong driveshaft in my car?
Old Dec 29, 2007 | 12:03 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: trans problem
you can't always trust a parts store so I'd research it on line a little and see if you come to the same conclusion as they did and or call ford and see if there are two diff part numbers..my auto equiped mustang did have a smaller u-joint than my 5 speed car and on the yoke of the auto car was like a balance ring..but all in all it shouldn't make a huge diff on the car cause I recently put a 5 speed driveshaft in a customers auto car with no problem as long as the driveshaft is properly balanced but a vibration during shifts may more so point to the tail shaft bushing...you have to remove the tailshaft= not to hard and then use a seal driver tool to tap out the brass bushing
Old Dec 29, 2007 | 01:41 PM
95greengt's Avatar
95greengt
ok thats what i thought well guess the bushing is the nest step in gettn rid of that F@#* vibration thanks for the info
mtgldr
Feb 3, 2024 09:00 PM
warwickbass
Sep 20, 2015 04:51 PM
97SN95GT
Sep 13, 2015 09:45 PM
tramphardrocker
Sep 13, 2015 08:56 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
