TKO600
Old Jan 21, 2008 | 08:24 AM
BlackFox's Avatar
BlackFox
Default TKO600
Never bought a new transmission before so was wondering what else I need to buy to slap this sucker on my block? What brands and size do you guys suggest? Cheapest one ive found so far is around is here http://www.latemodelrestoration.com/...1&comp=LRS
Old Jan 21, 2008 | 08:42 AM
r.barn's Avatar
r.barn
Default RE: TKO600
TKO 600 is good trans.
You will need.
New Bellhousing
New clutch
New yoke
New swap x-member or cut out and move stock one.
www.astroperformance.com has super T-5's also.
Old Jan 21, 2008 | 09:01 AM
BlackFox's Avatar
BlackFox
Default RE: TKO600
any particular brands or size in those parts?
Old Jan 21, 2008 | 01:07 PM
primetime5.0's Avatar
primetime5.0
Default RE: TKO600
just find the cheapest bellhousing you can, there all the same, and the same goes for the yolk...
edit the shifter that comes with it isnt the greatest, if you have the cash definetly upgrade it while its out
Old Jan 21, 2008 | 02:26 PM
telsonman's Avatar
telsonman
Default RE: TKO600
can't you just use the bellhousing from the stock t-5 on it???
also, how hard is it to put in a new cross member??? is it as easy as just welding it in???
Old Jan 21, 2008 | 02:40 PM
jtmustang's Avatar
jtmustang
Default RE: TKO600
i would like to get a tko too but they are just too much money right now
just had my t5 rebuilt with the ford racing kit carbon fiber blocker rings all bearings had it all done with the kit and royal purple for ander 450
Old Jan 21, 2008 | 07:07 PM
thesource's Avatar
thesource
Default RE: TKO600
Hit me up if you still need the TKO and parts to install it . I am a Tremec dealer as well asa Pro 5.0 and SPEC dealer as well .
Old Jan 21, 2008 | 11:50 PM
BlackFox's Avatar
BlackFox
Default RE: TKO600
What shifter do you suggest?
Old Jan 21, 2008 | 11:53 PM
BlackFox's Avatar
BlackFox
Default RE: TKO600
ORIGINAL: thesource
PM me with a price shipped to 73110. Need it complete so i can send it to a transmission shop and have them install it.
Old Jan 22, 2008 | 12:46 AM
primetime5.0
Default RE: TKO600
put it in yourself! I used an mgw shifter myself, much better than what came with it
