question
Old Jan 23, 2008 | 09:33 AM
GaryBisiniere's Avatar
GaryBisiniere
Default question
i have an opportunity to trade my edelbrock performer rpm heads with 1.9 valves for trick flow 2.02. my question is will i have to notch my pistons? i have stock 306 hypertechs with 9 to 1 for compression
Old Jan 23, 2008 | 10:10 AM
greenstreak9205's Avatar
greenstreak9205
Default RE: question
if they're twisted wedges you'll be fine.
Old Jan 23, 2008 | 11:10 AM
1991LX5.0's Avatar
1991LX5.0
it depends on what cam your running (im assuming its not the stock cam). Just remember to check it before you torque the heads down
Old Jan 23, 2008 | 12:59 PM
67mustang302's Avatar
67mustang302
Why would you make that head trade? You can still make awsome power with a 1.90 valve RPM head. And depending on the build, you may be better off with a smaller valve. Smaller valve = higher velocity induction charge.
Old Jan 23, 2008 | 06:34 PM
dman302's Avatar
dman302
See sig...compare to any TW 302 combo's out there.
Old Jan 23, 2008 | 10:57 PM
lxman1's Avatar
lxman1
Dman, did you have to do anything to the valve reliefs in the stock pistons to run that cam with 1.94's?
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
