What should I do?
Old Jan 23, 2008 | 06:52 PM
ExMan01's Avatar
ExMan01
Default What should I do?
Hey everyone,
I'm getting my taxes back and after paying bills, I'll have about 1000 to spend on the stang. right now i have trick flow street heat upper/lower intake, 75mm maf, 70mm tb, cai, headers, bassani exhaust, aluminum driveshaft, subframe connectors, 255 fuel pump.
now my question, what should i do with the money? here's what i've been thinking: 24lb. injectors, eibach springs, cobra wing, wheels/tires, short throw shifter, heads, whatya guys think? if you can think of anything else, let me know. obviously i could do a couple of these things, like shifter, injectors, and springs.
Old Jan 23, 2008 | 10:55 PM
lxman1's Avatar
lxman1
Default RE: What should I do?
Well, you're not making near enough power to justify 24# injectors so I wouldn't worry about those. I voted heads.
If you want more power, that's the way to go. If you want looks, go wheels and tires.
I would go with twisted wedge heads myself. You can run the 2.02 intake valves without piston mods. But since you are limited to $1000, I would suggest Edelbrock performer 5.0 pedistal mount heads so you can reuse your stock rocker arms and such.
Old Jan 23, 2008 | 11:02 PM
bighungrymatt's Avatar
bighungrymatt
get some nitrous
or some heads
Old Jan 23, 2008 | 11:07 PM
stangman94's Avatar
stangman94
how bout some gears and juice
Old Jan 24, 2008 | 06:24 AM
stang8689's Avatar
stang8689
patriot heads are only $900, you can you the rest for a cam
Old Jan 24, 2008 | 07:17 AM
lxman1's Avatar
lxman1
The Patriot heads would require roller rockers and possibly pushrods which will put him way over 1K.
