300hp
Ok so i am thinking about getting (once i get the money) AFR 165cc heads, Steeda #19 cam, and trickflow intake upper and lower manifold. With thisand some minorbolt ons that are in my sig would i be anywhere close to 300hp
Only get the AFR 185s if you have aftermarket pistons.
They will fit with stock pistons with a custom camshaft (and some select OTS cams), but why limit your camshaft grind because of the valve radial being to small.
Go with AFR 165s.
Go with AFR 165s.
ORIGINAL: 5spd GT
Go with AFR 165s.
Go with AFR 165s.
or you could get the 185's and intake, leave the cam and save up for a stroker. Then when you do the stroker you can get the cam, and just transfer everything else over to the short block
, At least thats how i think. (so you dont have to buy another set of heads when you realize that 165's dont feed a 331/347 very well, depending on if you are going to stroke it in the future that is...........
