93 cobra rear brake kit
Old Feb 4, 2008 | 02:41 AM
maiello2169's Avatar
maiello2169
Default 93 cobra rear brake kit
So I bought a "93 cobra brake kit" on ebay...Well needless to say, it didn't come with everything I needed to do the conversion. Why didn't I do five lug you ask? Because I already have 4-lug rims...lol. Money isn't THAT easy to come by around here as of now. So...I beleive I need to buy a 93 cobra master cylinder, e-brake cable and proportioning valve. is there anything else that I would need to purchase in order to make this a complete conversion? Oh and do I need to remove my gears for this conversion...because if I do I'm getting some 3.55's.....
Thanks a bunch people =)
Old Feb 4, 2008 | 02:43 AM
maiello2169
Default RE: 93 cobra rear brake kit
I actually bought this kit...took me a minute to find it.
http://cgi.ebay.com/ebaymotors/4-Lug...spagenameZWDVW
Old Feb 4, 2008 | 02:50 AM
92cobra's Avatar
92cobra
if your auto get 4.10s if your manual get 3.73s, you will hate yourself if you get 3.55s, just a tip.
As far as the brakes, i dunno.
Old Feb 4, 2008 | 01:09 PM
raven_ghostwolf's Avatar
raven_ghostwolf
ORIGINAL: maiello2169
As far as the master cylinder, e-brake and proportioning valve read through this first sn95brakes.com/4lug. As far as removing the gears... NO you do not have to remove the gears. You will have to remove the rear cover, then remove the pin from the center of the differential to push the axles in to remove the c-clips in order to remove the old axles.
If you do want to do gears at this time I would recommend taking your car to a shop that KNOWS how to rebuild rear ends to have them installed.
Nothing wrong with 3.55's for better take off and still get good highway drive-ability, but as 92cobra said 4.10's if your AOD and 3.73 if 5-Spd are good if your not going to be doing much highway driving. <-- Just my opinion
Old Feb 4, 2008 | 03:31 PM
maiello2169
Sweet sounds good. Thanks a lot to both of you guys for your replies. I'm gonna check out that link you sent me in a minute. Seriously, thanks again.
-Mike
BTW I have a 5 speed.
Old Feb 4, 2008 | 08:05 PM
Stimmel's Avatar
Stimmel
are the axles out of a 93 cobra? stock fox axles? this swap when done like this can be confusing i just did mine with stock axles and had to use north racecars brackets to make the brakes line up right
Old Feb 4, 2008 | 11:59 PM
maiello2169
No actually the axles are from a 93 cobra. So the swap shouldn't be that bad. I just needed some kind of guideline.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
squishbang
Sep 7, 2015 07:57 PM
Urambo Tauro
Sep 7, 2015 12:47 PM
Tyoung68
Aug 25, 2015 04:31 AM
MtnMustang
Aug 16, 2015 08:07 PM
