Really Loud Screeching?
Old Feb 4, 2008 | 10:06 AM
millert/a's Avatar
millert/a
Default Really Loud Screeching?
Pulled out of the driveway on this rainy day everythings good. Turn off the road and my cluth is really rough feeling when I press it in. When I start to press it in its like its stuck then it goes in fine. So after that I hear this minor screeching, think nothing of it its rainy maybe a belt got wet, but pull up to a stop light and push the clutch in and it sounded like I killed a baby pig. Its so loud when I press the clutch in and I checked under the car after coming back and its like something is slushing around under the car. Cant really see where though. Any ideas on what it could be? Dont know if my camera will record it the exhaust makes it freak out but Ill try.
Old Feb 4, 2008 | 10:29 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Really Loud Screeching?
Most likely the problem is the throw out bearing making the noise. The stiffness when you start to press in the clutch is probably a worn bearing retainer that the t/o bearing rides on. It's made of aluminum and does wear. Here's the stock one out of my car. See at the end it looks like it's expanded out, that's probably what's going on w/ yours
Old Feb 4, 2008 | 11:52 AM
millert/a's Avatar
millert/a
Heres a video I got of it. Youtube is kind of off with the sound but you hear it.
http://www.youtube.com/watch?v=b5dLBztAMWs
Old Feb 4, 2008 | 12:58 PM
millert/a's Avatar
millert/a
So is that what that sounds like to yall? If so how much is it to replace that?
Old Feb 4, 2008 | 01:43 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Yeah, that def sounds like the t/o bearing. If you're gonna replace it, may as well do the clutch assemand the bearing retainer also. Price will depend on type of clutch you buy. Expect about 3-4 hours labor.
Old Feb 4, 2008 | 06:12 PM
millert/a's Avatar
millert/a
So if im gonna get it fixed your saying I should go ahead and fix it all up?
If so thats fine would these be the parts Id need to fix this up?
http://store.summitracing.com/partde...p;autoview=sku
if there is more just tell me.
Old Feb 4, 2008 | 07:09 PM
stangbanger87's Avatar
stangbanger87
yep that is what pro50sc is saying if you are going to do it might as well change it all
Old Feb 4, 2008 | 08:41 PM
1fastzook's Avatar
1fastzook
ORIGINAL: millert/a
The clutch kit that you picked has a throwout bearing included.Heres the link to the bearingretainerhttp://store.summitracing.com/partde...p;autoview=sku
Old Feb 4, 2008 | 09:32 PM
lxman1's Avatar
lxman1
Unless a snake got in the belhousing like my friends ranger
Old Feb 5, 2008 | 07:39 AM
millert/a's Avatar
millert/a
So I just need the clutch in the first link and what your link is and I can get those parts go straight to the shop and it will be fixed? I just dont want to have to order anything else . And thanks a lot guys this is so helpful.
