Flywheel question...
Old Feb 5, 2008 | 01:59 PM
djh1121's Avatar
djh1121
Default Flywheel question...
Teach me something today...
What is the difference in a 157 tooth and 164 tooth flywheel. The reason for asking is I need to replace the ring and need to buy one this afternoon.
It's for a manual trans.
Old Feb 5, 2008 | 02:02 PM
bighungrymatt's Avatar
bighungrymatt
Default RE: Flywheel question...
Jason, go with the 157 tooth one balanced to 50oz
what clutch did you decide on?
Old Feb 5, 2008 | 02:14 PM
5spd GT's Avatar
5spd GT
Yep, go with the 157 tooth. It matches the starter teeth better.
157 tooth, is 157 teeth all the way around the ring gear.
Older engines had the 164 teeth ring gear.
Old Feb 5, 2008 | 02:19 PM
djh1121's Avatar
djh1121
OK, thanks...
Matt - it's between the centerforce and king cobra... Need to make up my mind.
Old Feb 5, 2008 | 02:23 PM
bighungrymatt
narrowed it down to 2, I recommend the centerforce dual friction
Old Feb 5, 2008 | 03:17 PM
djh1121's Avatar
djh1121
ORIGINAL: bighungrymatt
I hear ya, but the king cobra is almost 1/2 the price of the centerforce. I've read good and bad about both of them.
Old Feb 5, 2008 | 04:46 PM
gearbanger's Avatar
gearbanger
i have had the king cobra clutch and i did not like it at all! spec or centerforce all the way.
Old Feb 5, 2008 | 05:19 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: djh1121
And there is a reason for that.
Old Feb 5, 2008 | 10:29 PM
OnyxCobra's Avatar
OnyxCobra
So true Bernie, when it comes to buying parts for your car it's not worth cheaping out on the parts man. Get the better product.
Old Feb 6, 2008 | 01:06 AM
bighungrymatt
Did you decide which one you are getting Jason?
